File upload widget doesn't show on a mashup
aetxeberria
We are using a FileUpload widget on a mashup, but it doesn't show.
To discard other posible issues, we've created a new mashup with only a FileUpload widget, but when we view the mashup, the widget doesn't show.
We turn on the ThingWorx debug toolbar to show log, and this is the error:
12:01:14 INFO - In-page logger initialized.
12:01:14 INFO - ThingWorx Mashup Runtime vundefined
12:01:14 ERROR - An error occurred while calling fileupload::renderHtml, Id = "fileupload-5". Exception: s.match(...) is null on line number 1 in file mashup-common-widgets-runtime.js?_v=9.1.3
12:01:14 ERROR - An error occurred while calling fileupload::afterRender, Id = "fileupload-5". Exception: f[0] is undefined on line number 1 in file mashup-common-widgets-runtime.js?_v=9.1.3
THW Platform: ThingWorx 9.1.3
THW Apps: ThingWorx-Apps-9-1-1
Does anyone else have this issue?
Thanks in advance,
PaiChung
22-Sapphire I
(To:aetxeberria)
Not sure if this will work for you, but a while back there was a strange bug that caused the widget not to show, however after doing some 'config' changes on the widget properties, just change some options and saving, it would display again.
I forget what version that was on when it happened, but you can try.
I've tried but doesn't work...
@aetxeberria
Have you tried uploading the latest extensions recently?
Because it may occur when the extensions are interfering with this Fileupload widget.
kindly revert back
Regards
Bhawna
We uploaded extensions a few months ago and fileupload widget works perfectly until a week ago.
During that week we started to change some widgets style properties (we don't use custom css, we use style properties panel). I don't know if it would be the problem. We've created a new mashup with only fileupload widget for that reason.
