We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
Hi ,
I have a data table with the data shape below, just found a very strange behavior, for the service:
var values = me.CreateValuesWithData({
values: { WorkOrderId: "NA", DeviceId: "OP10-OvenREHM00001" } /* JSON */
result = me.FindDataTableEntries({
values: values /* INFOTABLE */
The result always return empty as long as the field Estimated is true , otherwise it work well. Is it a known issue ?
Thingworx version: 8.4.4
Database: Posgresql 10.x
-----------Table Structure-----------------
Seq
INTEGER
KEY | |
STRING
KEY | |
DATETIME
KEY | |
STRING
KEY | |
DATETIME
BOOLEAN
This behavior is working as per product specifications.
You can find more information in : https://www.ptc.com/en/support/article?n=CS292316
Hi seanccc,
FindDataTablesEntries() is listed as only searching on set indexes which might be why you are seeing some issues. Other alternatives include QueryDataTableEntries() or if you have the key for the record you are searching for GetDataTableEntryByKey() is better if you are looking for one record.
Note: If using GetDataTableEntryByKey(), it is a best practice to wrap the call in a try/catch block as GetDataTableEntryByKey() will throw an error if it does not find the record.
-Andrew
Thank for the information. The find* service work again if remove the default value setting.
Sean
