Hi All !
I have a problem needs to be solved.
When the user enters the ThingWorx website, I want he can directly access the custom login Mashup instead of the login window provided by ThingWorx.
What should I do?
Thanks!
Lei
What do you have as your login window?
are you using an Organization? then direct them to <server>/Thingworx/FormLogin/NameOfOrganization
If you have your own page created, then give them a link to that page where they authenticate and then it redirects them to Thingworx
You can do this by passing their User name and Password or setting up SSO
