Error importing: error, Import Failed: Unable to update thing: Term simulator not found.
Ramesh, from where are you accessing your ThingWorx instance? Is it a Dev Zone instance or local?
I am getting the same error. I was following the tutorials. I click on subscriptions on Foundation_Quickstart_Services, click on subscription info and check enable and then try to save it but it says Error importing: error, Import Failed: Unable to update thing: Term simulator not found for me.
Aanjan Ravi, I am accessing in Local.
Ramesh, have you imported the required extensions?
Got the same problem when i want to execute the subsciption code of the subsciption code of the tutorial.
Explore the imported entities.
save failed, status: "Internal Server Error", message: "Import Failed: Unable to update thing: Term simulator not found"
