Hi Guys I have some miner problem which is starts to bugging me.
I am creating gadgets, I want to reuse that widget, so I need to control services and properties via Mashup's (gadget's) parameters.
I have created several gadgets (EnableParameterEditing is active). If I use the gadget as standalone item in standard Mashup (static or responsive) i can pass the parameters quite ok. If I use those gadgets in Dashboard(s) I am lost. I dont know how to pass required parameters between dashboard and gadget or between different gadgets. I see that I can edit gadgets's parameters manually, but this is not as flexible as I would want it. I would like to do as many work as possible in fully automatic way. Plus, this Edit Gadgets parameters mashup does not always work (see pictures below) and I cannot figure out why. I have One identical gadget, this is added to the same dashboard, but in different groups. If I choose Edit Parameters at the gadget's config icon one shows me a table with all (one) off my parameters that I can edit, the other one shows nothing.
So I have 2 question:
How can I pass on parameters to gadgets inside the dashboard?
And what the heck is going on with that EditParameter section of a gadget?
Thanks a lot guys
That's not easy to answer, lets try...
Once said previous things:
Hope it helps
