Hi everybody!
Is there any solution to create a QR Code internally in Thingworx? We tried it with the google api you explained in another topic but unfortunately our customer is not allowing this external apis to happen. In this system it is forbidden to use external apis.
Is there a possibility maybe something in github that I did not find for now to integrate a qr code extension in Thingworx to have it local.
Try following extension,
sathishkumarc14/TWX_QRCode_Generator: Generate and Read QR Code within ThingWorx
Hi @MS_12859766 ,
It appears that this post may answers your question. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Abhi
