The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Geocoding errors in Thingworx mashup using google maps widget
tcarroll
1-Newbie
I am pulling in a .csv file with city names in the location field of the spread sheet. I also have a service running to turn those locations into points on the map. However, when I bring in the .csv file about 50% of the locations are actually in the wrong place.
For example:
My team and I are all located in Greensburg, PA on the spread sheet. When i upload the sheet into ThingWorx it places half of our team in Greensburg, PA and half of us in random locations around the world. It is very inconsistent and the locations seem to change every time I load the file in.
Does anyone have any insight into this problem or have ever ran into something similar?
1 REPLY 1
mgoel
(To:tcarroll)
Hi Ty Carroll​,
Just wanted to follow up with you on the community thread as it seem to be related to either the data source in used or custom service been used to map data points.
It will be helpful if you can share the spreadsheet and use case to further debug the issue. I will reach out to you for more details directly.
Mohit Goel
