Hi ,
I am having one use case in that i need to check how many times a end user can change/update the particular field value. for Example
| ID(Primary key) | UserID |
| 1 | 101 |
| 2 | 102 |
above table there will be restriction to update userID (Max 2 times can change/update a userID for ID 1) same will be for ID 2. how we can achieve this in TWX 9.1.
Hi @VaibhavShinde,
I guess you can create customized services for such field updates.
In those customized services, you may achieve the following logic:
if changed_time_of_xxx is over 2
then return false
else
update the field
changed_time_of_xxx increases 1
return true
You may want to create another table where stores how many times a field has been changed (i.e., changed_time_of_xxx).
Hi @VaibhavShinde,
then return false
else
update the field
return true
