Get all enabled schedulers
MO_10216552
Is there a way I can get a infotable of the enabled schedulers using GetEntities? What filters do I have to apply for that?
Use this code:
// result: INFOTABLE dataShape: "RootEntityList"
var t = ThingTemplates["Scheduler"].GetImplementingThingsWithData();
var query = {
    filters: {
        type: "EQ",
        fieldName: "Enabled",
        value: true
var params = {
	t: t /* INFOTABLE */,
	query: query /* QUERY */
var result = Resources["InfoTableFunctions"].Query(params);
2 REPLIES 2
Use this code:
var query = {
    filters: {
        type: "EQ",
        value: true
var params = {
MO_10216552
(To:nmilleson)
Thank you! It's perfect
