Hi ,
I want to get all the projects from a TWX platform excluding PTC's project.
Hi @PP_10477715 ,
If you are expecting to retrieve project list in TWX JS code. Kinldy find the attached code FYR. If not please explain more about your query.
/////******////// To get all project details in TWX code /////******//////
let params = {
maxItems: undefined /* NUMBER {"defaultValue":500} */ ,
nameMask: undefined /* STRING */ ,
type: 'Project' /* STRING */ ,
tags: undefined /* TAGS */
// result: INFOTABLE dataShape: RootEntityList
let projectList = Resources["EntityServices"].GetEntityList(params);
/////******////// Remove the project name - PTCDefaultProject from all project list /////******//////
let params1 = {
fieldName: 'name' /* STRING */ ,
t: projectList /* INFOTABLE */ ,
value: 'PTCDefaultProject' /* STRING */
let result = Resources["InfoTableFunctions"].NEFilter(params1);Thanks & Regards,
Arun C
As i can see in above service first we are fetching all the projects and then we are using filter on that,
So unnecessarily we are loading all the rows, also i have multiple ptc's app deployed on platform and i have to exclude those.
May be we can use the tags, but i don't know how to exclude multiple tags.
one another service is SpotLightSearch, that may be we can use , where we can pass the not expression (the project name not starts with PTC) but i am not sure how we can use that expression.
Don't overengineer this. How many projects are on your systems? Even it's 100, if loading those is an issue, you're in trouble.
You can use this to name-filter projects starting with PTC:
let params = { nameMask: "(?!PTC).*", type: 'Project' };
result = Resources["EntityServices"].GetEntityListByRegEx(params);
But this is not guaranteed to filter out all projects coming from PTC. Especially older extensions (e.g. Analytics) might not comply with the naming scheme or use tags.
