Get default value from C edge SDK
AliBenBelgacem
I'm struggling to get the default value from my edge csdk code server
Details:
I created a property when creating thing :
TW_PROPERTY("DefaultValueTest", "Description", TW_INTEGER);
        TW_ADD_NUMBER_ASPECT("DefaultValueTest", TW_ASPECT_DEFAULT_VALUE, 150);
        TW_ADD_NUMBER_ASPECT("DefaultValueTest", TW_ASPECT_ISLOGGED, TRUE);
I put as default value 150.
When i try to fetch the value of my property in another service in the same c project:
int lDefaultValueTest = TW_GET_PROPERTY(THING_NAME, "DefaultValueTest").integer;
I always get zero as result !.
I wonder why I am not having '150' since it's the default value  ??
As a workaround, i set the property after the definition of the property
TW_SET_PROPERTY(thingName, "DefaultValueTest", TW_MAKE_INT(150));
The problem here is when, i set a new value somewhere in other service and I restart my program, it's always reset to 150 and cannot be updated
Any idea how to fix this.
Thank you
0 REPLIES 0
