Greetings,
I would like to use the grid widget but have no vertical lines displayed. Basically a columnular list of rows but with not vertical lines.
Is this possible?
I've tried messing with all the style properties, but haven't been able to remove all vertical lines.
Robert, I tried clearing out all styles, and unfortunately looks like that is not possible. You can clear pretty much everything other than the row and column lines. How many columns are you displaying? An alternate way would be to use the List widget and clear the ListBackgroundStyle.
