Hi, is there a way to launch the download automatically when you get the link ?
So, the user don't have to click the link in order to launch the download.
My ultimate goal is to to an export with ExportInfotableAsExcel. Then, download that file created automatically.
Yes, use a navigate widget, with input url with the link and trigger Navigate by expression or service event.
Hello, Thanks
Yes, It is working. I found out the answer right after I posted this article.
For some reason, it wasn't working because something wasn't linked.
Frederik Grondin: Unfortunately, we do not have any standard functionality to achieve this currently and would recommend you to write custom code to achieve required functionality.
-Durgesh
Durgesh, did you see my answer?
Carles Coll : Yes, Carles I missed that and thought Frederik looking for some direct Thingworx service. Agree with your approach and should solve the purpose here.
Frederik Grondin : Please review Carles comment and confirm if that solves your query.
Durgesh
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
