GetLaunchPointMenuNameForThing
VictoriaFa
Returns wrong (old) Menu entry when executed with AssetId
Hello @VictoriaFa,
Is it possible to detail the scenario in order to reproduce it ? Also what is the ThingWorx version being used ?
Thank you,
Hello @VictoriaFa
Can you please provide more detail regarding the issue.
VictoriaFa
(To:odukiya)
When executing the  service: GetLaunchPointMenuNameForThing
with parameter launchPointDescription: "AssetDetailMenu" the result is "PTC.SCA.SCO.AssetMonitor.AssetDetail.C_ActionMenu" (correct result as configured)
adding the parameter thingName with any Thing as value the result is the base Menu "PTC.SCA.SCO.AssetMonitor.AssetDetail.ActionMenu" (which is not configured in the
PTC.Factory.C_LaunchPointConfigurationThing_8.5.0_02)
The custom Launchpointconfigration is enabled
ThingWorx 8.5.0-b12
