Getting "502 Bad Gateway nginx" error while accessing https://servername/Thingworx/WS
RK_10356304
Hi Team,
Please help on this issue.
Thanks in advance.
9 REPLIES 9
@RK_10356304 ,
Can you give us a little context on how and where you're trying to access this?  Is it for a TWx SDK? EMS? Other?
Nick
@nmilleson
The data is flowing from AWS kinesis stream to ThingWorx 9.3.3 via WebSocket Protocol.
@RK_10356304 ,
I'm not very familiar with Kinesis streams.  Are you subscribing to that stream somewhere and then sending to ThingWorx?  Typically when I have to connect to the ThingWorx websocket, the address is formatted as wss://servername/Thingworx/WS
-Nick
@nmilleson What configuration needs to be done on ThingWorx Composer side for setting up the websocket connection?
@RK_10356304 ,
ThingWorx is already set up to accept web socket connections.  However, I've only interacted with it using either the SDKs that are available in different programming languages, the WS EMS (which uses lua scripting), and KepServer.  You may want to check out the SDKs here to get a better idea of how to set up the ws connection to ThingWorx.
-Nick
@nmilleson  How to verify on ThingWorx composer side that whether our Websocket connection is working fine i.e. successful or not?
@RK_10356304 ,
If you go to Monitoring and click on Remote Things, you can view the unbound and bound remote things and their respective connection statuses.
-Nick
You can use postman tool or the extension of Chrome "Websocket Test Client" to verify the websocket connection
This issue might occur due to Thingowrx SSL .jks file is misplaced. Please restore the .jks file on original location or configure the .jks file path in server configuration side.
Thanks!
