I am using ThingWorx Platform Release 9.3 and DatecodeSP7
Issue with bind properties.
We've bind property using script to a remote thing. The property does not appears in the UI of the thing (development HMI) but appears using services to retrieve property definitions.
In consequence, we cannot use the subscription or alert function to trigger processes on data change.
This issue happen since seeral time, at the very begining of our project (september 2023) we weren't facing this issue.
Maybe there is a max amount of bind properties in Thingworx ? The fact is that I can no longer bind properties, even manually.
@GM_9460437 ,
Sorry this post was overlooked, I did notice that you had opened a case on this same subject.
If you are still experiencing the issue please review the logs on both sides of the communications.
If there are error information it will assist in identifying a solutions.
Please let us know if we can assist.
