Hi Team,
I have to implement one functionality in which if I click on google map open tooltip should close. Is it possible in thingworx?
Hi @IS_10098292.
Could you elaborate more on the issue? Is it the Google map tooltip you're referring to? Which version of ThingWorx are you running? Which Google maps extension have you installed?
Regards.
--Sharon
