Hi developers!
I have a problem with the google map widget.
I have given some locations to the google map.
The first time I load the mashup is shows normally.
But after I navigate to other mashup, and return to this mashup, it becomes weird. Like this:
The strange thing is that I can still see the locations and the google logo, but the map can't display normally.
Could somebody help me out? I'm in a bit rush! Thanks!
Lee
Lee, what version of ThingWorx are you using? Is the map in a Tab widget?
ThingWorx 7.1
the google map widget is the extension that I download from the ThingWorx market.
Hi developers!
Why Baidu's Widget extension zip file can not be imported thingworx, import tool does not support a .zip file?
Wendy, 'Import from file' is for entities/ data. Since you are importing an extension, you would need to select Import under the Extensions section in the same Import/ Export menu.
I did same, but its taking too long....
