Shared with Jive Anywhere
Within Thingworx you have two parts to make a Grid editable.
First you set the Grid as Editable, then you have to go into Configure Grid columns to indicate which columns can be edited.
So yes what you are looking to do is possible.
Yes but I'm not talking about columns, I'm talking about rows.
I want the second column to be editable but, within the second column, only the second and third rows.
If I do what you say, I make all the second column editable, which means also username would be.
Sorry I must've misread your question.
What you are looking to do is not possible, you could accomplish that by building a grid in a repeater
Ok, thank you very much for your answer
