For some reason the row text in my grid widget will not set at the size I have in the Style Definition assigned to it. The only way I can get the text to enlarge is by going to row format, and then assigning a fixed style. When I do this however, the row style will not change when the row is selected.
Is this a bug or am I going about getting the text size to enlarge wrong?
Thank you,
Mike
A case has been opened on the PTC eSupport portal. Please follow the link below to view the case using the case number provided.
https://thingworx.ptc.com/appserver/cs/portal/
Case Number: 12143605
For continued support from the ThingWorx Technical Support Engineers, please submit all support inquiries to the PTC eSupport Portal. The General forums have shifted to Peer support.
Thank you,
Saeed
