I have used grid widget in my mashup. I want to change the text size of rows in the grid. I have changed the text size of RowbackgroundStyle & RowalternateBackgroundStyle in properties of grid widget. When I loaded the mashup I didn't find any changes in text size. I want to change the size of text below the header in the grid widget. Are there any ways I can do that?
Hi ,
You can change the text size of the Grid contents by by RowFormat - State Formatting - Fixed Style - Text Size.
Hi ,
Thank You Janet Joseph Antony Dass for reply, It is helpful, now I am able to change the text size of the grid contents.
Glad it worked !
