Grid advanced widget. Not modify column width during Runtime
aetxeberria
11-Garnet
We are using grid advancet widget, and the user can modify the column width during runtime .
Is it possible to freeze column width?
Thanks in advance.
Hi @aetxeberria ,
Which version are you using?
As far as i know In 9.2, we can set the column width automatically or manually using pixel, percentage, or fraction values.
Bhawna
We set column width using pixels, but during Runtime the user can modify it...
We are using 9.1.3.
Thank you
GuillaumeL
(To:aetxeberria)
I am not aware of such capacity on Advanced Grid (even using configuration JSON I don't think this is manageable)
In 9.3, with the new grid, you will have this feature.
