Help with accessing a user in the ThingWorx API
TravisPickett
I am working on a custom extension that will create users in ThingWorx.  Once a user is created does anyone know how to access that user object so the extensions can be modified?
paic
(To:TravisPickett)
If you are interested in the User Extensions (properties of the user as listed in the Extensions section) that is in a ThingShape called UserExtensions
Did you manage to access user extensions via Java? I am working on similar functionality right now
Is this in Java or JavaScript?  If it's in Java, you can do the following:
User user = (User) EntityUtilities.findEntity(username, ThingworxRelationshipTypes.User);
