How Thingworx Logging and Store the Data
SathishkumarC
Hi.
I am having a doubt regarding, How thingworx Log and Store the Property value?. Please explain about this.
Thanks.
Sathishkumar C
Do you want to understand the flow of logging properties ? If yes then by checking the logged check box of any property makes it eligible for logging the values coming into a value stream assigned to template/thing .These logged properties can be checked by executing services like querypropertyhistory of value stream .
Or your query is about something else ,like you want to know the code flow or something ?
