We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
I know, How add javascript library to extensions in eclipse..
first, market place download
'AngularJS_Extension-ext' in 'ptc-windchill-extension-1.7.0-03' in 'TW_Download_PTC Windchill Extension'
'AngularJS_Extension-ext' extensions metadata.xml is
<Entities>
<ExtensionPackages>
<ExtensionPackage name="AngularJS_Extension"
description="AngularJS Libraries for Thingworx"
vendor="Thingworx"
packageVersion="1.0"
minimumThingWorxVersion="5.0.0" >
<WebAppResources>
<FileResource type="WEBAPP" file="Runtime/lib/angularjs" description="Library folder for AngularJS" />
</WebAppResources>
</ExtensionPackage>
</ExtensionPackages>
</Entities>
so I add my Extension Project metadata.xml
<WebAppResource>
<FileResource type="WEBAPP" file="Runtime/lib/abc" description="Library folder for AngularJS" />
</WebAppResource>
and Add folder Extension Project / webapp / common / Runtime / lib / abc
and copy Javascript files....
and ant Extension Project...!!
but Import Error
Source '\ThingworxStorage\extensions\IntegrICT_Chart_Extensions\webapp\common\Runtime\lib\abc' does not exist...
How fixed My Error??
Please Help...
Hi Seung, can you please confirm if this is the error you are seeing in Composer during the import process or in the eclipse?
