Hey everyone,
I have a ValueStream which is connected to different things.
Now I will reset the hole ValueStream-object. I know I have to execute the "PurgePropertyHistory"-service, but I don't know what I have to enter in the field "propertyName". Can someone help?
David, each Value Stream is dependent on its Thing. So running a purge on a Thing, will only clear out that Thing.
There are 3 different purges available on the Thing - PurgeAllPropertyHistory, PurgePropertyHistory and PurgeSelectedPropertyHistory.
With that being said, you need to give a start and end date or it won't purge/ delete your data.
That help me a lot, but my thing has only the "PurgePropertyHistory".
Hi David,
PurgeAllPropertyHistory and PurgeSelectedPropertyHistory was added on a later version, you should be on a "old" TW version.
Carles.
