I´m trying to parse a XML output came from a POSTXML request to add a infotable, but it´s being hard.
During my research I found some examples in the community but nothing expected.
I have this code that´s working fine:
var resultXML = Resources["ContentLoaderFunctions"].PostXML(params);
var returnXMLString = resultXML.*::Body.*::editItemResponse.return;
var result = ""+returnXMLString[0].toString();
My problem is that I don´t know how can I navigate into output using the sintaxy "resultXML.*::Body.*::...."
My XML output has some information that I want to put in a infotable but is more than one information that´s would be necessary a kind loop.
<WarehouseInternalId>alm</WarehouseInternalId>
<CurrentStockAmount>9999</CurrentStockAmount>
<BookedStockAmount>0</BookedStockAmount>
<env:Envelope xmlns:env="http://schemas.xmlsoap.org/soap/envelope/">
<env:Header/>
<env:Body>
<ns2:receiveMessageResponse xmlns:ns2="http://www.ptc.com/">
<receiveMessageResult>
<![CDATA[<ptcMessage xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="../xmlschema/general/requests_new/ptc.xsd">
<MessageInformation version="2.000"><UUID>97228f82-4984-dab7-3314-2b2058908c58</UUID>
<Type>Response</Type>
<Transaction>stocklevel</Transaction>
<StandardVersion>1.0</StandardVersion>
<SourceApplication>dts11buzios8480</SourceApplication>
<CompanyId>10</CompanyId>
<BranchId/><Product name="PTC" version="12.1.19"/>
<GeneratedOn>2017-12-15T16:54:12.555-02:00</GeneratedOn>
<DeliveryType>Sync</DeliveryType>
</MessageInformation>
<ResponseMessage>
<ReceivedMessage>
<SentBy>PPI</SentBy>
<UUID>e9a028b2-522e-4d3a-ad9e-d5c518ac03fe</UUID>
<Event>upsert</Event>
</ReceivedMessage><ProcessingInformation>
<ProcessedOn>2017-12-15T16:54:12.555-02:00</ProcessedOn>
<Status>OK</Status>
</ProcessingInformation>
<ReturnContent>
<ClosingStockDate>2017-12-15</ClosingStockDate>
<ListOfReturnItem>
<ReturnItem>
<BranchId>1</BranchId>
<ItemInternalId>.compras1</ItemInternalId>
<ReferenceCode/>
<ListOfStockBalance>
<StockBalance>
<WarehouseInternalId>fab</WarehouseInternalId>
<CurrentStockAmount>35067</CurrentStockAmount>
<LotNumber/>
<Address/>
</StockBalance>
<StockBalance>
<WarehouseInternalId>cq</WarehouseInternalId>
<CurrentStockAmount>0</CurrentStockAmount>
<LotNumber/>
<Address/>
</StockBalance>
<StockBalance>
<LotNumber/>
<Address/>
</StockBalance>
<StockBalance>
<CurrentStockAmount>662</CurrentStockAmount>
<LotNumber/>
<Address>11</Address>
</StockBalance>
<StockBalance>
<WarehouseInternalId>CQ</WarehouseInternalId>
<CurrentStockAmount>40</CurrentStockAmount>
<LotNumber/>
</StockBalance>
</ListOfStockBalance>
</ReturnItem>
</ListOfReturnItem>
</ReturnContent>
</ResponseMessage>
</ptcMessage>]]>
</receiveMessageResult>
</ns2:receiveMessageResponse>
</env:Body>
</env:Envelope>
What´s is the best way to acomplish that?
Thank you,
Douglas
var resultXML = new XML(content);
var xmlresult = resultXML.*::Body.*::receiveMessageResponse.*::receiveMessageResult.*;
var xmltext = String(xmlresult);
var newXML = new XML(xmltext);
xmlresult = newXML.*::ResponseMessage.*::ReturnContent.*::ListOfReturnItem.ReturnItem.ListOfStockBalance;
//result = xmlresult;
var params = {
infoTableName : "InfoTable",
dataShapeName : "StockBalance"
var infoTable1 = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var newRow = new Object();
//PARSE XML PUT INTO INFO TABLE
// iterate through xml and add to info table
for each (var tag in xmlresult.StockBalance) {
newRow.WarehouseInternalId = tag.WarehouseInternalId;
newRow.CurrentStockAmount = tag.CurrentStockAmount;
newRow.BookedStockAmount = tag.BookedStockAmount;
newRow.Address = tag.Address;
infoTable1.AddRow(newRow);
// return info table
var result = infoTable1;
var params = {
