I have eight mashups for which i have created landing page. I go and click on each link in landing page to visualize those mashup. I just want to auto generate those mashups. How can i do that. Is there any way.
Sounds like you are trying to cycle the mashups? You can use a Refresh Timer Widget to fire a service that resolves the mashup name and tie that to the container mashup.
You want to auto generate all 8 mashups all together as a new page while loading the landing page ? Are you using navigate widget in landing mashup to open new mashups on click ? If above two statements are true then can you try calling navigate service of every navigate widget on mashup load of landing mashup .
This way when your landing mashup will be loaded new mashups will get open automatically .Select new as "TargetWindow" property of navigate widget so that it opens 8 new mashups while loading the landing mashup .
If the requirement and use case is different then elaborate more
Thanks ,
Mukul Narang
How can i achieve this by using timer template.
If you have the 8 mashups ready and a logical way to determine which one should show, you can use a contained mashup and assign them using a service.
Usually in Thingworx you would use the Home Mashup feature, which can be assigned to either an Org or to Users. (each can refer to and use the same master)
