Hello Expert,
I am working on one application for need to send instruction bi-directional (EMS to Thingworx and Thingworx to EMS )
First part i completed for send data EMS (Java code) to Thingworx but I don't know about how to send to data Thingworx to EMS.
If you a any code for both Thingworx or EMS please share me or any steps or any suggestion.
Mayank
Mayank, the Edge Help Center covers a lot of information with regards to using the EMS in conjunction with the lua Script Resource. Few example properties, services and events scripts are provided with the EMS package as well.
Ravi,
You have any code in Thingworx and Java for two way communication.
Mayank, Are you trying to use the Java SDK, the Edge MicroServer (EMS), or the EMS in conjunction with a Java application? Regards, Meghan
Yes Meghan , I am working on both end Thingworx and Java.
Thanks RAVI,
I got my ans. in Two way Communication using Edge Help Center
Thingworx to EMS -> Using getProperties in EMS code create service , to receive value from Thingworx Properties changes.
Mayank@@@@@
Please provide a link or some basic code to retrieve data from Thingworx to Java SDK.
