Line chart has one x and one y axis but I want one more Y axis in Line chart.
Please let me know How can we add secondary Y-axis in Line chart widget
You may look into widget modification and custom extensibility to develop your own solution. Attached is documentation/guides.
can you please help me to writing script in Custom widget for adding Secondary Y-axis in Line chart.
I am very new to develop Custom widget so please share some codes and related files and libraries for the same.
Thanks in advance
You can load the existing widgets in eclipse to see teh structure and code:<Tomcat location>\webapps\Thingworx\Common\thingworx\widgets
As Carles mentioned, the standard chart has multiple Y axis unlike the marketplace ones.
Hi Rohit, the standard TW charts has multiple Y-Axis, but the marketplace ones doesn't.
