How can we connect ThingWorx with ODBC data sources.
vvaidya
Hi ,
I wanted to connect my ThingWorx application with an ODBC data source. I know how to work with JDBC drivers to connect to any JDBC compatible database. Similarly I want to connect with ODBC compatible data sources.
Thanks in advance !!!!
Thanks and regards,
Vishal Vaidya
4 REPLIES 4
Hi Vishal,
I have the same question. Have you found something to connect to ODBC?
Best,
Arian
Aanjan
(To:avanhuelsen)
Arian, to start off with, here is the Martketplace download link for the JDBC Connector extension. You can use your custom driver file to create and use your connector extension. All you would need is a valid Connection URL, Driver Class Name and Connection Strings. Here are some JDBC configuration examples from the Help Center.
Ravi, thanks for the links. It helped me to setup the connection to my SQL Server!
Aanjan
(To:avanhuelsen)
No problem, glad to have helped!
