when I want to display the values on graph by using Startime and Endtime parameters then it will take only the system date and time, but I want to display the values of my custome timestamp values which are sending through the device.
if your custom timestamps are recognized as Thingworx datetime, then you should be able to set that to be the X-Axis field or the Start and End time values.
Thanks for reply,
How Could I make recognize my custom timestamps to the Thingworx Datetime ?
Could you please help me out
