For instance I want to change a textbox's read only status from within a service. The text box readonly property doesn't have an input or output on the mashup like some other properties do. I tried something like this first
me.textbox-10.ReadOnly=false;
but this failed as the textbox-10 nomenclature caused an error, which leads me to believe there is some other ID for textbox-10
If this functionality that you want to use, I recommend with this widget code at its basis, customize and create your own widget that allows binding to that property.
