How do I create a Mashup with javascript
Huaxu
8-Gravel
Like creating a Thing with code
VladimirRosu
(To:Huaxu)
Hi @Huaxu,
There is no ThingWorx OOTB API that allows creating a Mashup through code.
The Mashup is an entity type that is supposed to be edited and created through Composer only.
Can you please share more details of your use-case so we may suggest an alternative path?
VladimirRosu
(To:Huaxu)
Hi @Huaxu,
I wanted to be able to generate mashups directly from the template from code, which would greatly improve my development efficiency
jensc
(To:Huaxu)
As Vladimir says, there doesn't seem to be any way of creating mashups through a service.
But there is an entity type called "Dashboard" which could perhaps be used in your use case:
Find more information here.
Jens
