I'm pulling addresses from a cloud CRM system and writing them to a grid and then binding the lat/lon to a google map for marking position. I want to use the shippping address instead. Is there a way to have the Google Map Widget accept an map a physical address instead of pushing lat and lon to the location value?
-rob
The Google map widget doesn't do that unfortunately.
what you can do is show it by long/lat (can do a lookup based on address) and then show the address in the tooltip of the marker.
This will make it look like it is mapping it by address
Thanks Pai. I presumed that was the case. We will attempt to use the google api to geocode the addresses from the inbound system on-the-fly when the lat/lon is unavailable from the other database.
rob
