How do you batch create things?
lliangjb
Hello, everyone!
    I want to create 100,000 things in Thingworx,one by one create is too slow,Did you have quick way to create itimport or   code to create?
    I THANK very much!
ankigupta
(To:supandey)
In addition to Sushant details; I recommend you to do it in a try-catch block to avoid any issues.
Please refer to following link which shares details on Creating a Thing in Service Script
I hope it helps.
5 REPLIES 5
supandey
(To:lliangjb)
Hi Ju Bin, you can create things programmatically and for that you can use the EntityService from System > Resources
So for creating n number of Things you could call that CreateThing services in a loop.
Hope this helps.
ankigupta
(To:supandey)
I hope it helps.
Thank you very much. I'm going to learn this code
Another recommendation would be to do it in blocks ( 100 by 100 or alike ), why? Creating long lasting transactions it's a bad choice in TW. To do this, you will have to create a timer which triggers the Creation Services, and on each trigger consume like a hundred.
supandey
(To:CarlesColl)
Thanks Carles, that's quite an important note.
