i want to use vertical divider in my mashup but in 30 days free trial there is only horizontal divider so how i apply css to divider?
Hello.
Take a look at this thread (the post by CMorfin in particular) for an example of using custom CSS to modify the divider widget. I don't think it's exactly what you asked, but should get you going in the right direction.
Thanks!
-- Craig A.
Hello.
Thanks!
-- Craig A.
Hi @Ru.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
