Hi
It works well with creating MQTT Thing and communicating.
But I want users to conveniently register the device and see the sensor values.
It registers its own information and devices through DB and Mash Up.
Each device must be published according to Thing's MQTT settings.
To do this, I need to change the topic value of the configuration of MQTT Thing every time I load each device.
Can I build this easily using mashups instead of Thingworx Composer?
Register the device - The topic to be published by the registered device [eg Device / 001 / Temp] - Topic setting to subscribe [Mappings to Configuration of MQTT Thing]
I'm going in this form.
Any suggestions to me? Give me a solution.
