How to Authenticate the API for Windchill Odata connector in Thingworx when using SSO Authentication
VV_14105315
Hi Folks,
I have a requirement to download the files of Windchill objects into Thingworx repository. I am getting the Link of files inside Thingworx using Odata Connectors. I am able to generate the file in Repository but when I try to open the file getting error "Failed to load PDF document."
Below is the code I am using :
// result: JSON
let inputJson = Things["ptc-windchill-integration-connector"].downloadAsZip({
respondWithZip: false /* BOOLEAN {"dataShape":""} */,
$expand: undefined /* STRING {"dataShape":""} */,
    objectId: <objectId>
// result: JSON
let csrf = Things["Thing.ODataConnector.ProdMgmt_TH"].GetCSRFToken({
$select: undefined /* STRING {"dataShape":""} */
    item = inputJson.items[0];
let params = {
url: <file_url> /* STRING */ ,
headers: {
"CSRF_NONCE": <Nonce token>,
                "Accept": "*/*",
                "X-Requested-With": "XMLHttpRequest"
// result: BLOB
let binaryContent = Resources["ContentLoaderFunctions"].LoadBinary(params);
    result = binaryContent;
    let fullPath = "/test4/" + item.name;
    Things["SupportRepository"].SaveBinary({
path: fullPath /* STRING */,
content: binaryContent /* BLOB */
What is wrong in my code to authenticate it while downloading it in Thingworx Repository.
Thanks in advance.
VV
Hello VV,
You should be getting the CSRF_NONCE token first and then pass it to subsequent calls - see example bellow:
let ParamA = {
    url: Windchill_URL + "/servlet/odata/v3/PTC/GetCSRFToken()",
const NONCE_VALUE = Resources["ContentLoaderFunctions"].GetJSON(ParamA);
let ParamB = {
    headers: {
        CSRF_NONCE: NONCE_VALUE
result = Resources["ContentLoaderFunctions"].PostJSON(ParamB);
 If you still get some error it would be helpful if you provide ThingWorx/WC log snippets.
slangley
(To:VV_14105315)
Hi @VV_14105315
Was the response you received helpful?  If you still have questions, please let us know.  Otherwise, please mark the response as the Accepted Solution for the benefit of others in the community.
--Sharon
