We have 5 locations on google map widget on double click of any of the location we are able to navigate single mashup.
But we have 5 mashups for 5 locations we want to navigate to respective mashup on double click of that location.
Could anyone help us to achieve this thanks in advance.
Anil Kesana
You may look into using Tooltip mashup, upon binding locations to correspondant tooltip locations:
Hi Polina,
I did not get you completely could you please elaborate a bit?
If you look at the Google Maps widget configuration (the part in the screenshot above), there are differnent tooltip locations you may assign. For example, if you have a google location picker widget, you may bind it to one of the Tooltip Locations, and then assign a tooltip mashup.
This would not fit your described use case, but there is no way to assign individual double clicked events on different locations.
