Hi ,
I am looking to add padding in between containers (responsive). Is it possible to maintain padding between containers? if yes how we can achieve this?
You can add padding with something like:
.myContainer .widget-content {
padding-left: 60px !important;
or a margin with:
margin: 60px !important;
or a margin with:
Hi @nmilleson ,
Yes its working fine. can we be able to achieve this by using Style properties> Padding .?
I haven't tried it with Style properties. I prefer using CSS when I can because I can bind the custom class and change the styling during runtime, whereas with Style properties I don't believe you can do that yet.
