How to add a dynamically created thing in a network programmatically ?
done11
I am creating a thing using code and then I want to add that thing into a network using code.Any idea how to do it ?
supandey
(To:done11)
Hi Digital, could you please help me understand further on your requirement of adding to network? Which network are you referring to?
jamesm1
(To:done11)
You can add your thing to the network using the AddConnection service:
var params = {
            to: "ChildThingName" /* STRING */,
            connectionType: "Contains" /* STRING */
        // no return
        Networks["NetworkName"].AddConnection(params);
Edit: If it is a top-level connection, leave the from parameter as undefined.
done11
(To:jamesm1)
Thanks James it was really helpful !
