How to add data tag term using javascript code
tsharma
Is there any way to add terms in an existing data tag dynamically using javascript in service?
supandey
(To:tsharma)
Hi Tushar, did you already check the AddVocabularyTerm service? You can call this to add terms to DataTags
var params = {
  term: undefined /* STRING */
// no return
DataTags["TestTag"].AddVocabularyTerm(params);
Hope this helps.
