How to alter the sequence in Responsive tabs in already developed mashup.
For eg. If A tab is at 3rd place and I want to bring the same tab at 5th Place.Is there any configuration settings.
I don't see a viable solution here. You may look into altering the tab widget or developing your own. Attaching documentation on custom extensibility.
Alternatively, you may look into data-driven menus.
