I want to apply StateDefinition only for 1 Column. So, I applied StateDefinition to a particular Column and it's working fine. But, when ever I'm hover over on the table It's showing the default one. Can anyone suggest how to apply StateDefinition for RowHoverStyle also?
Hi Abarki
This issue is fixed by setting background, secondary background and foreground color to transparent and line color to white. The line color is set to white so that the rows doesn't merge while hovering. Thank you for following it up.
Hi Aksah1,
Can you confirm what product you are working with and version? Hence I can get the right guys to view your Post.
Thank you.
Asia
Hi Abarki
Hi Akash1,
Thank you for providing information about how the issue got fixed, this is very beneficial to other community members.
Kind regards,
abarki
