Hi Thirulok,
Consider the below example for simple property bindings:
- Select the Widgets tab.
- Drag the List widget to the upper-left corner of the layout.
- Verify that the Data tab is selected in the upper-right panel and click the Add entity icon
- Click the Select Entity drop-down list to expand it.
- Select Thing Templates.
- Type geti in the Select Services filter.
- Click the Add icon for the GetImplementingThings method.
- Select the Mashup Loaded? check box.
- Click the Done button.
- Select the GetImplementingThings service.
- Drag the All Data row to the list of the Data panel..
- Select Data.
- Click under the scroll bar in the lower-left panel to scroll down so that AutoSelectFirstRow and DisplayField are both visible in the list of properties.
- Click DisplayField to expand the drop-down list.
- Select name.
- Select the AutoSelectFirstRow check box.
Add a property for the selected thing template:
- Click the Dynamic check box.
- Click under the left-most scroll bar to scroll down to the Properties category.
- Select the Properties category.
- Click the Add
![](/legacyfs/online/thingworx/7125_pastedImage_5.png)
- Click under the scroll bar in the Data panel to scroll to the bottom.
- Click Expand
- Click under the scroll bar in the Data panel until both the name of the selected row and the EntityName are visible.
- Select the name row for the selected row of the Data table.
- Drag the name row to the EntityName row.
- Click above the scroll bar in the Data table to scroll up to GetImplemetingThings.
- Select the GetImplementingThings row of the Data table.
- Click under the scroll bar in the Data table to scroll down to GetProperties.
- Drag the SelectedRowsChanged event to the GetProperties service.
- Click Expand
- Drag a Gauge to the upper-middle Layout panel of the widgets panel.
- Drag a property(temperature) from the Data panel to the Gauge.
- Select Data.
- Click the Save button.
- Click the View Mashup button.
![](/legacyfs/online/thingworx/7126_pastedImage_11.png)
You can observe that the property value changes based on the selected inputs. This is one way of binding the properties to get the dynamic values.
If this is not the scenario you are trying to implement, then please provide me the details of your requirement.
