Hello everybody,
I am having diffucult to create charts binding with tags from my PLC.
I am comunicating my foundation with my PLC tags throught of Industrial Connectivity. It is working well.
I want bind this tags to label chart, where the data refresh when my tag change in my PLC
I am using this guide to orientation: https://developer.thingworx.com/en/resources/guides/display-data-charts
But the value, in the guide, are inserted manual into infotable.
Does someone has a solution to this?
Leonardo.
Hello there,
I was able do it!
The correct was to use the service "getpropertiesvalues" to label chart and I was using "getproperties".
It resolved my situation and I hope who it can helps someone.
Leonardo.
Hello there,
I was able do it!
Leonardo.
