I would like to achieve the same call through thingworx what i am able to do it through postman(attachment for reference) .
I tried using snippets but was not successful.
I have to pass 2 header information and 4 body information with the url to get the JSON as a reply. How to send it through thingworx ??
Can you also show the snippet you've tried so far and how you set it up?
Thanks!
Hello PaiChung,
Below is the snippet i have used. I have passed the body in content.
//JSON object to send
var HeaderJson = {
"Content-Type" : "application/json",
"Accept" : "application/json"
var BodyJson = {
"grant_type" : "",
"resource" : "",
"client_id" : "",
"client_secret" : ""
var params = {
headers: HeaderJson /* JSON */,
url: "" /* STRING */,
content: BodyJson /* JSON */
// result: JSON
var jsonresult = Resources["ContentLoaderFunctions"].PostJSON(params);
Sunay
Hello PaiChung,
Is my script wrong??
Sunay
What errors do you see in the logs?
also try this as a post text and set service return to string
Hello PaiChung,
I tried with both the options
var HeaderJson = {
'Content-Type' : 'application/json',
'Accept' : 'application/json'
var BodyJson = {
'grant_type' : 'client_credentials',
'resource' : ' provided resource'
'Trace ID' : 'provided proper trace id',
'client_secret' : ' provide client secret'
var params = {
url: "https://comlete url" /* STRING */,
// result: STRING
var result = Resources["ContentLoaderFunctions"].PostText(params);
logger.warn("testing Response:"+result);
PostText output message: {"error":"invalid_request","error_description":"AADSTS90014: The request body must contain the following parameter: 'grant_type'.\r\nTrace ID: \r\nCorrelation ID: \r\nTimestamp: 2018-07-04 14:16:51Z","error_codes":[90014],"timestamp":"2018-07-04 14:16:51Z","trace_id":"","correlation_id":""}^Accept=application/json:Content-Type=application/json
Although the message says body should contain correlation id and others, i am able to get the data from postman without those parameters.
logger.warn("testing Response:"+jsonresult.Result);
PostJSON output message: undefined.
Also i have tried sending the body embedded with the url to receive the token by encodeURI(body)
"https:complete url/token?encodeURI(grant_type=&resource=&client_id=&client_secret=)"
result is undefined.
am i missing something in my script.?
Sunay
Hello PaiChung,
var HeaderJson = {
var BodyJson = {
var params = {
// result: STRING
Sunay
Hello PaiChung,
Any info that you want to add up on this..??
Thanks.
Hi @sbt,
Please try the following script :
var HeaderJson = {
"Content-Type" : "application/x-www-form-urlencoded",
var content = "grant_type=client_credentials&resource=http://some_url&client_id=xxxxxxxxxxxxxx&client_secret=xxxxxxxxxxxxxx'"
var params = {
url: "http://{some_url}" /* STRING */,
content: content
// result: JSON
var jsonresult = Resources["ContentLoaderFunctions"].PostText(params);
Himanshu
If my response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question
