How to call services from a thing and return JSON format through REST?
acc
7-Bedrock
7-Bedrock
I created a thing with services that able to return a INFOTABLE.
I did tried to create another services that used .ToJSON() and return result in JSON base type.
Both way i couldn't get the result in JSON format when i use postman GET method.Untitled.jpg
REST return  Unexpected 'I' and i don't know what is this mean.
Can somebody tell me how to make it?
Thanks in advanced!
ttielebein
(To:acc)
Calling services via REST API are POSTs not GETs. You need to change the type to POST and provide a content-type (likely just application/json). Hope this helps!
ankigupta
(To:acc)
Hi Ang CC​, Try running the service directly from the composer and check result. Also, make sure to set datashape of the infotable in the script itself.
Check Application logs/Script logs for any error(s).
I hope it helps.
Ankit Gupta
ttielebein
(To:acc)
acc
7-Bedrock
7-Bedrock
(To:ttielebein)
Thanks Tori Tielebein​, POST is the correct way with the header content-type.
