There's a ThingWorx Time Series Chart, I want to change the Y scale manually after auto-scale Y axis. Is it possible?
Y-Axis min and max are bindable, but autoscale is not.
So to be able to change the Y scale after render, you'll have to start with autoscale off and some default in the min/max
then you can use two inputs to change those min and max values.
